How can make upgrade for obdII actia (lexia) scanner , from /B to /C
  • dema2
    Hi to all, i write in english corner, because en frances for me is a very problem.
    I have a problem with my clone actia3, obd scanner from China, Is Revision /B, i need to upgrade this to Revision /C, for to have a full work, can bus, with all model of psa citroen cars, i have read that on this forum a big Man have created a file called "NLC", that used with psa checker, upgrade the actia scanner to revison /C and change the serial nuber, with a not black listed number, i can pay for this file.
    Many thank in advantage to all friends here, for any suggestion
    Dema2 or Paolo
    S. Domingo
    Dominican Republic
Nom : 		Schermata del 2014-04-19 00:29:14.png
Taille :		136,2 Ko
  • cedrsan
    • 364
    Hi,
    You can find NLC & more infos in this thread => http://www.lesamisdudiag.com/diagbox...-de-serie.html
    Regards
    Dernière modification par cedrsan, 19 avril 2014, 01h02.
    • dema2
      Envoyé par cedrsan
      Hi,
      You can find NLC & more infos in this tread => http://www.lesamisdudiag.com/diagbox...-de-serie.html
      Regards
      Hi dear friend Cedrsan
      Thank for your reply
      I have read on this closed post, but also with the help of google traductor is very hard for me to understand all message, for this i ,at the end write in this English corner, i am Italian , i have difficult also with english , thinks with Frence lenguage, if you can help me i very appreciate your help.
      I have also read on this post
      I have replyed to this on #350 and #354 post, but for the moment, i do not have any suggestion, for me French lenguage is a problem.
      I hope to meet an help for , if is posible, to contact in P.M. mister NLC and take accord for to obtain the file for to update via psa checker the clone actia3
      Thank for your time and help
      Excuse for my bad english
      dema2
      • cedrsan
        • 364
        You just need to send PM to NLC when you are allowed to send one (Forum Rules).
        • dema2
          Envoyé par cedrsan
          Thank for your reply Cedrsan
          I tried to send a pm to _nlc_, but are not yet enabled, can you tell me how to do it in order to be authorized to send PM, thanks a lot
          Best regard
          dema2
          • tmvk-
            • juillet 2014
            • 21
            Envoyé par dema2
            Best regard
            dema2
            I have same problem, didn't find any advice from forum rules.
            (5 posts to forum for opening attachments)
            Envoyé par Messages privés / Message Vbulletin
            tmvk-, vous n'avez pas les droits nécessaires pour accéder à cette page. Cette interdiction peut résulter de plusieurs faits :
            1. Votre compte d'utilisateur n'a pas les droits nécessaires et requis pour afficher cette page. Essayez-vous de modifier le message d'un autre utilisateur ou tentez-vous d'accéder à des fonctions d'administration ?
            2. Si vous tentez d'envoyer un message, l'administrateur a peut-être désactivé votre compte, ou il se peut que votre compte soit en attente d'activation.
            Dernière modification par tmvk-, 04 juillet 2014, 07h45.
            • tmvk-
              • juillet 2014
              • 21
              Found answer, for PM have to post 16 or 20 messages. Quite problematic, because my French skills isn't good.
              Bonjour, il te faut avoir entre 16 et 20 messages postés pour avoir accès au mp. donc bientôt bientôt^^
              • mitzot
                • juin 2015
                I would too like to get in touch with mr NLC - I guess everybody knows why... Anyone willing to help me?
                • dave chante pas
                  • 26
                  I am in the same situation...try to "upgrade" from B to C :/
                  • patber
                    • 4210
                    Good day my friends very easy just take a look here.Thank you.
