Easily breaking fan temp motor. Current limiter?
  • tmvk-
    • juillet 2014
    • 21
    Hi,
    In Finland we have problem in winter:
    1 Heater flap gets some moisture to its seals
    2 Temperature goes under 0`C
    3 Moisture on seals freezes
    4 I start my C5 in morning, still -10`C
    5 Stepper motor tries to change it's position. The flap doesn't rotate with it.
    6 This breaks flap's plastic hole (around motors opposite head)
    7 Causes that fan blows allways only hot or freezing air.
    I have thinked this could be easily prevented with current limiter. Could it be done for a stepper motor. Ecu should not know, at there is something.
  • tmvk-
    • juillet 2014
    • 21
    Here is picture about this:
    • lotusman
      u should clean those flaps seals
