Remote keys low range
  • tmvk-
    • juillet 2014
    • 21
    Remote key range have been slowly decreased to 2 meters.
    Is there something component (eg capacitors), which get old?
    C5/2.0/2001
  • Namerows
    • juillet 2014
    Have you simply checked current batt voltage?
    • tmvk-
      • juillet 2014
      • 21
      Changed new battery many times.
      • Lunacy
        • 137
        You need to change the key. in the past I have the same problem on a VW Passat 3BG.
        ## Certains de mes outils de Diagnostic ##
        -VCDS / VAS / ODIS / DiagBox / Clip / WoW! / KTS 520 / EsiTronic / IDS Ford / Tech 2 GM /Multi-Diag Actia / Abrites ...
        -== ProTrace Coding ==-
        ###########CoTech#############
        • rommanuss
          It is probably due to electronic components aging which results in a frequency offset, lowering the transmitted power at the expected frequency of the car.
          Some remote keys include a frequency setting (potentiometer or software setting) and some generic key/remote sellers are able to fix this kind of issue.
          • 1 6 D
            In Golf 5 and similar cars there is coding about limitation of range by ussing remote
