I have problem with brakes! I have changed brake pads, oil, vacuum pipes from vacuum pump and vacuum pump. And after 2000-3000km I lost almost all brakes! Problem is when I press brake pedal it brakes for 2-3 sec and then It pushes back toward me, brake pedal, and becomes stiff! Brake servo is dry so no problem with that. Also I connected to Lexia and under ABS and braking system there are no Faults. I heard that Citroen has problems with Hydro Block in ABS/ESP part (TRW ESP VSC 440)... Also I have noticed that car brakes almost great (100%) when it is cold and by the time it reaches 90 Celsius it looses brakes. So please tell me where to look and what to do?
Bad braking...
