Aide Seat Ibiza
  • sleepers
    Banned
    • 23
    Aide Seat Ibiza
    salut j'ai un souci avec ma seat voila le log
    Saturday,25,May,2013,15:24:53:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 6L - Seat Ibiza/Cordoba
    Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
    VIN: VSSZZZ6LZ8R142024 Mileage: 88170km/54786miles
    Address 01: Engine Labels: 038-906-019-AXR.lbl
    Part No: 038 906 019 NL
    Component: 1,9l R4 EDC G000SG 7458
    Coding: 00102
    Shop #: WSC 04941
    VCID: 6ED9D0612A8C249
    VSSZZZ6LZ8R142024 SEZ5Z0H0301970
    2 Faults Found:
    19557 - Motor for Intake Manifold Flap (V157)
    P3101 - 35-10 - Open or Short to Ground - Intermittent
    19558 - Motor for Intake Manifold Flap (V157)
    P3102 - 35-00 - No Signal
    Readiness: 1 2 0 0 0
    Address 03: ABS Brakes Labels: 6R0-907-37x-ASR.lbl
    Part No SW: 6Q0 907 379 AG HW: 6Q0 907 379 AG
    Component: MABS 8.0 front H05 0002
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0002202
    Shop #: WSC 04941 785 00200
    VCID: 820114D1DE14B09
    Part No: 6Q0 907 379 AG
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 08: Auto HVAC Labels: None
    Part No: 6L0 820 043 E
    Component: CLIMAtronic PQ24 3805
    Shop #: WSC 00000 000 00000
    VCID: 2855E67998E83A9
    No fault code found.
    Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
    Part No: 6Q1 937 049 F
    Component: 000B BN-SG. 2S36
    Coding: 08332
    Shop #: WSC 04941
    VCID: 3E7920213A6C949
    1 Fault Found:
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 AE
    Component: 0H AIRBAG VW5 0C 0010
    Coding: 12360
    Shop #: WSC 04941
    VCID: 7AF1EC3166C4789
    Address 17: Instruments Labels: 6L0-920-xx3-17.lbl
    Part No: 6L0 920 823 C
    Component: KOMBIINSTRUMENT AGD V04
    Coding: 00102
    Shop #: WSC 00000
    VCID: 2D5B176DE70A1F1
    1 Fault Found:
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: 0305 GATEWAY CAN 2S36
    Coding: 00014
    Shop #: WSC 04941
    VCID: F0E54E19B0B8B29
    1 Fault Found:
    Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
    Component: IMMOBILIZER AGD V04
    Coding: 00102
    Shop #: WSC 00000
    Address 44: Steering Assist Labels: 6Q0-423-156.lbl
    Part No: 6Q0 423 156 AB
    Component: LenkhilfeTRW V270
    Coding: 10111
    Shop #: WSC 04941
    VCID: 6FE7CD652D862D1
    1 Fault Found:
    Address 46: Central Conv. Labels: 6Q0-959-433.lbl
    Part No: 6Q0 959 433 E
    Component: Komfortgerát 0002
    Coding: 00016
    Shop #: WSC 04941
    VCID: 3D7B272D376A8F1
    End ---------------------------------------------------------------------
    merci d'avance pour votre aide
  • sleepers
    Banned
    • 23
    slt alors personne na une idée ?
    • aldrik
      • 387
      direction assiste electrique ou mecanique
      • sleepers
        Banned
        • 23
        direction assisté mecanique pourquoi quelle rapport avec les erreur ?
        • tdi35
          • 32
          L'autoradio est d'origine ou pas?
          • sleepers
            Banned
            • 23
            non plus d'origine !!! pourquoi ?
            • tdi35
              • 32
              Débranches ton autoradio et refais un diag, tu devrais avoir une réponse de tous les calculos.
              • sleepers
                Banned
                • 23
                ok je test et je te tiens au courant
                cela veut dire que mes défauts vienne du fait que j'ai changer mon autoradio ?
                • tdi35
                  • 32
                  Uniquement tes problèmes de communication avec les calculateurs.
                  • sleepers
                    Banned
                    • 23
                    salut alors mon probleme persiste meme en changant de calculateur alors si quequ'un a une idée je suis preneur !!!! merci d'avance pour votre aide
                    • tdi35
                      • 32
                      Dèbranches ton autoradio et reessaye.
                      Pourquoi commencer par le plus compliqué et coûteux?????
                      • sleepers
                        Banned
                        • 23
                        merci deja pour ta reponse mais sa fait deux ou trois jour que je roule sans autoradio et sa me le fait toujours et pour le calculateur j'ai pris celui d'un pote t'inquiete
                        • badaboom
                          • 19
                          Bonjour , peux tu me donner le type moteur et l'année , le defaut concerne la vanne egr (si je ne me trompe pas, je n'utilise jamais vagcom mais V157 il me semble que c'est ça).
                          Je pourrais t'en dire plus demain (si j'ai un peu de temps)... apparement il n'y a pas de d'alimentaton:No Signal..Open or Short to Ground .
                          Jette un œil au faisceau et fusible (même si ça m'étonnerai) et regarde quant même le tuyau de dépression (même si ça n'a rien a voir avec le défaut..mais c'est le plus courant)
                          Désolé mais les défauts vagcom , ça me parle pas
                          Peux tu nous donner les symptômes: voyant allumé? manque de puissance? ...
                          bonne soirée
                          • sleepers
                            Banned
                            • 23
                            salut merci encore pour vos réponses alors concernant la vanne egr c'est normale je l'ai remplacer par un kit forge d'ou l'erreur ce qui m'intrigue c'est l'erreur01314 - Engine Control Module
                            49-10 - No Communications - Intermittent qui revient sur tout mes capteur électronique comme montrer dans le log ma voiture c'est une ibiza 6l 100 ch année 2008 et code moteur axr voila en espérant une aide de votre part merci d'avance
                            • badaboom
                              • 19
                              Salut, En fait le défaut de communication est intermittent donc soit :
                              -Le défaut est apparu après avoir débranché le calculateur moteur ou autre, du coup puisque tous les calculateurs communiquent ensemble par multiplexage ils affichent un défaut de comm. avec celui-ci et donc tu effaces tous les défauts et c'est tout.
                              -Tu as un problème de faisceau qui coupe sporadiquement la communication de ce boitier ou de gateway.
                              Mais je pense plutôt à la première solution.
                              Donnes des news.
