resultat de mon vag com pour a4 tdi 110 cv de 1997
  • david45380
    bonjour a tous
    je voulais votre avis sur mon vag com d audi a4 avant tdi 110 cv de 1997
    j ai un peu de mal a le dechriffrer
    j ai besoin de vos lumieres pour le diag moteur, pour la clim et equippement car je sais que mes air bag sont hs
    merci d avance auplaisir de vous lire prochainement
    Monday,04,November,2013,16:56:20:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 253300km/157393miles
    Address 01: Engine Labels: Redir Fail!
    Part No: 028 906 021 GN
    Component: 1,9l R4 EDC 00SG 1437
    Coding: 00002
    Shop #: WSC 06325
    VCID: 61C3BB5DEB528B1
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    37-10 - Faulty - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
    Part No: 8E0 614 111
    Component: ABS 5.3 FRONT D21
    Shop #: BB 24303
    VCID: DBBF09B5493E211
    No fault code found.
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 B
    Component: A4 KLIMAVOLLAUTOMAT_D73
    Coding: 04143
    Shop #: WSC 06325
    VCID: 2757E545C5F6351
    1 Fault Found:
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
    Part No: 8D0 959 655 C
    Component: Airbag 7 Audi 0301
    Coding: 00102
    Shop #: WSC 06325
    VCID: 36693801125C5C9
    10 Faults Found:
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    44-10 - Short Circuit - Intermittent
    01219 - Rear Side Airbag Igniter; Driver Side (N201)
    29-10 - Short to Ground - Intermittent
    01220 - Rear Side Airbag Igniter; Passenger Side (N202)
    01217 - Side Airbag Igniter; Driver Side (N199)
    01218 - Side Airbag Igniter; Passenger Side (N200)
    00588 - Airbag Igniter; Driver Side (N95)
    28-10 - Short to Plus - Intermittent
    00589 - Airbag Igniter 1; Passenger Side (N131)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00-10 - - - Intermittent
    Address 17: Instruments Labels: 8D0-919-0xx-17.lbl
    Part No: 8D0 919 034
    Component: B5-KOMBIINSTRUMENT D10
    Coding: 00140
    Shop #: WSC 00186
    VCID: E6C92841827C6C9
    Address 25: Immobilizer Labels: 4A0-953-234.lbl
    Part No: 4A0 953 234 F
    Component: IMMO AUZ9Z0V5214041 D77
    Coding: 00000
    Shop #: WSC 00866
    VCID: 254BEF4DBFFA271
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8LO 862 257 D
    Component: ZV-Pumpe, Funk D03
    Coding: 08768
    Shop #: WSC 65535
    VCID: 55AB9F8DAF1A771
    16 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01373 - Alarm triggered by Radio Ground Contact
    35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    01361 - Switch for Anti-Theft Alarm; Close
    29-00 - Short to Ground
    01360 - Switch for Anti-Theft Alarm; Open
    01362 - Close Switch for Tailgate/Trunk (F124)
    01363 - Switch for Central Locking; Driver's Door (F59)
    27-00 - Implausible Signal
    01364 - Switch for Central Locking; Passenger Door (F114)
    01365 - Lock/Unlock Switch; Interior
    28-00 - Short to Plus
    End ---------------------------------------------------------------------
    Address 35: DTCs cleared
    Address 01: DTCs cleared
    Address 08: DTCs cleared
