bonsoir,coupur moteur donc passage a la valise, code defaut P 1200,P 0003????????????????????merci a tous
coupure moteur ford focus 1.8 tddci
Fait le filtre a gasoil en premier ! Puis le régulateur de pression comme dit ricomerco
Envoyé de mon GT-I9195 en utilisant TapatalkCommentaire
non sur la pompe sur comman rail c est le capteur de pression [IMG]http://www.lesamisdudiag.com/image/jpeg;******,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMDRsUFRAWIB0iIiAdHx 8kKDQsJCYxJx8fLT0tMTU3Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjclHyU3Nzc3Nzc3Nzc3Nzc3Nz c3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//AABEIAFoAfgMBIgACEQEDEQH/xAAcAAABBQEBAQAAAAAAAAAAAAAAAgMEBgcBBQj/xAA+EAACAQMCAwUEBwMNAAAAAAABAgMABBEFIQYSMRNBUWGRIn GBwRQjMkJysdEVUqIHJDNDRFNiZXN1kqGy/8QAFwEBAQEBAAAAAAAAAAAAAAAAAAECA//EABwRAQACAgMBAAAAAAAAAAAAAAABEQIhAzEyEv/aAAwDAQACEQMRAD8A3GiiigKKKKAooooEyPyLnGT3DxqP29ww9 iBB480vT0FOXX9GPxCqlxfdT299w8IJpI1l1FEkCMQHUg7HxFb wx+8qSZpYmlvyfZ+ioPE8zfpSGF+39tjX8MH6k08RgmlDpWVRh b3RH1mpzn8CIvyrv0Mkb3l2T/q4/LFSAK6Bk9aDlsGhjEYd35fvSNzH1pwzsp3UEeOa4V3pLjagdW4 Q9QRTiOH+zURdlp+26GoHqKK5mg7RXAc12gKKKKBm5+wB5iqfx wMXfDh/zWL51cbj7A94qo8cLmbh8+GqxfOu3B7hnLpaPhRS5sqhKgZp1B lASACRvXJpHrq9a4zsGIUnbyFKDEpk9c0EbUNQjsmtxIjN9ImW FeXuJzufLanWlQj7a+teTxMPrNJ/3CP8jU3liJ2gXzq0JMZDJkEEZqRAMA1FMXNaMkPsE9MbYpzT4p IYmEshdiepqSPL451y54e4butRsrcXFwnKsaHpliBk+Q61jF//ACr61eWNxZX8L25mjMfbWxMbJkYyK07+UXTdbv0jXTS8lkY8TQ Lg5YNkHx9PCs0TRp2uDDeQsnKN1detWB7ui8c65Y2kOnLE1zLD lZLu+n789MAEnHT4dauGhcYuxb9sXds+fsi3t2Tl95LHPoKz9r IxjCpjHgKW+lXcdus8p7NHXmTmO5HupqSmrS8Y8OwMqXGr2sTt 0SR8N6VPsNY03URmwv7a47sRSBj6Vili08FyEit4rh2bZHTJPp vVou9audKWKNeHNMe4++GmK8n8J/OpQ0y4GUGPGqnxv10I+GqQ/Oq9c8Y6zLj6Oba2wMcoRnH/AKqLNxDqWp3GmWepRxOyahDIk8Q5cjmxgj4104ZrOEy6apLlvZ DAe8GnASE9vHwpHO4YAKSuM04j8w6EeRrmqMccxwSRSkGY/jSpniQ4cMDjuFETxsCIyTg75oPM1yzmu2sTAobsbtJX3xhRnJq cqPtk5+GKlkge+m1k5u8CljkKkLgjvp1ds1HlkCt1ZttgtLtpA 4YgYAPjmkxoPGs14/4gSPX1sUwRbRDnP+Jt8enLWkTFlicp9oKSPfisF1DTbi5nkuZZ mlnkPM7t1Y0gWHRZY9TugqL0+0T0XxPpTHEWoNcXJjQHCDCIOm B0Fefw5eNo6XsE4AM4AVz3jfK/lXZDzSCRQXPci95oqTpF1+zJptSuQsggAEK4wGkOcfAAE+lMXk epXkRvCzTTzksQBsgztnzPcBXk8QXZV4rRCCsG7EdGc9T+Q9w8 6ah4lew0uURTMbiX2I0B7icH5+nnUECXUri0vfo/Zi4l/cVN/UfnXu6Zq3M6dvC9rIuGUk8wBHn3VYdCtdNjtC1xGrXk4DTzfvN jp5AdAOgrzOIrMoUOnvH2Dbry4JfzPh7qo13SdQi1KwhuoZFYS IC3K2eU94p+ecQR9o5PID7RHcPGsu4US/06VLpFJJGHAZUDr4Hb02rQ9JvRqccgjZ4ZoTyywyqCVz0OxwQe 40Q7+01D8rxuo2ySRtkZG2c947qetbxbhuXkdMjmHOB7Q8dqGt 5+YP8AzdmHQlMEfHemoYJreR2js7Yc3Uxvgn+GmhNeMtIjZOAK UQg3OPiabQTui8wWPbuOTXRbqd3ZnPnUDcpidt15zjGBT0I9k5 XlyelKVFXYAUoUCS699Z9rWkGyuWX7Ub+1G3l4VfZSo7qgahap fQGJjyt1Vh901Rm09gkjBCBk+NRl0+S0uFZQVGe7pXvatp13aY klhyqf1ibqRUcXMcicj7g/9UVRtXgzeTZGwYD4dKrslt/PrcdcybD3cxq+6taI7yeJHUVU749hcRvygyRyCRUzjnx1APmCa gnRvcrDN9YcIOUDx6fImrHpvEKC1W3urEExQnlbHcBUJFtbuwk ms2L9oAyjoScjI9+ARUvROwvYykqmJgWhfmHjsD7jtQerpyadr EUuq3YmiKz8pRJWCDp7I7+8d9W3h+JY9aDRPhGtGBUkkkBlx6Z PrVe4fg/Z9g9rdZhaCUzCXopGc5z094q28OW5ZpNRYALOipAAMYj65x3ZJ 6eAFUe9igVzNdzUR2iiigKKKKCMbqBmCH73TIpubskflywPkNq Vcoq27sqgEBiCB0OKi2P1qI0ntsSwJbc4xQNXcx7MiJS2dsn3V SNX0S9eYzWCRgnfsuXlBrRuyj/u0/4jwqPe/Vo5T2Tt027zVsZhNazSQdldRmCfG3Odj5Z6VReItLvOdhHNbsf azGZN9sH5/Dbxr6LsreGeDM8McmWOedQc+tIvNPsuyC/Q7fGOnZL+lQfKenX2q20gezaSPJ3yNse6tQ0O60q5WO4uIpnkG A6k8mT37D9avsumWEZPZ2Nsv4YVHypVna24njxbxdf3BWogd0/hzRLySO5kiupUXDJbz3DvEp7vYJxt51axjFNxKqjCqAPACl91Q KzXVNIFOLUHa7RRQFFFFB//2Q==[/IMG]
sur la pompe gros gris ou noir je connais pas les valeurs si tu veux le faire au multimetre mais c est le defaut qui ressort avec ton outil diag
heu desole c etait le lien pour te montrer une photo j ai du faire une mauvaise manipCommentaire
Il faudrai d abord savoir si ton moteur est un 1.8 TDDI ou 1.8 TDCI..... Sinon, commence par le filtre a gazole.Laurent de Rouen (76)
Mécanicien AUTO, VUL et Pl.
Je suis disponible pour tout travaux, coup de main et/ou conseil avec outillage.Commentaire
par Prodrive42Bonjour,
J'ai un Peugeot Boxer 3 de 2014 avec le moteur Puma 2.2 HDI 130
Suite à la casse du moteur (bielle passé à travers...-
Canal: Peugeot - Citroën
par thibaut57200Bonjour à tous,
Je sollicite vos connaissances en ce jour pour m'aider à trouver le problème sur ma série 1 116i F20 Moteur N13, elle à 112...-
Canal: Bmw
par timticBonjour,
Merci de me lire et de votre aide :J'ai le voyant antipollution et le message d'un problème antipollution à l'ordinateur d'une C2 1.4...-
