Update PSA DiagBox WITHOUT Internet! V7.23 Allready PATCHED
  • Scarymistake
    • 19
    Update DiagBox V7 Allready PATCHED
    I also put in the Install iso
    (from de Master Debutant)
    First un-install old DiagBox
    Installation :
    Installing the ISO
    you will have version 07.01, you must use this version only for 'manual activation'
    After activation, shut duwn DiagBox and start it up and you will have version 07.02
    Ready to Update But use only the of-line updates (otherwise he will be deactivated) and then you must start over again
    Use only 32bit windows
    Torrent link
    PSA DiagBox WITHOUT Internet! V7.04 Allready PATCHED Scary Torrent
    Tanks to Buck Rogers
    Video how to install V7 Already PATCHED And update Windows 7 32bit
    [video=youtube]http://www.youtube.com/watch?v=9BDNdnBifaE[/video]
  • stupsi99
    • septembre 2013
    this is only update to version 7.22 ???
    stupsi99
    • 206s16cool
      • 221
      hello,
      you can do the update to 7.22 to 7.23 with your file?
      thank you
      • jhojo
        • septembre 2013
        Any update on the subject? Is this v7.22 or v7.23?
        • Nokia
          • septembre 2013
          Je n'arrive pas a l'installer sur windows 8...
          • grisou
            • 27
            prévue pour XP.
            possible sur win 8 mais 32 bits et ne pas déconnecter internet pendant l'installation
            mais le sujet est traiter sur le site
            • grisou
              • 27
              Envoyé par grisou
              prévue pour XP.
              Envoyé par grisou
              prévue pour XP.
              • angelsaid
                • 13
                bonjour jarrive pas a installer il me donne un message d’erreur
                • Scarymistake
                  • 19
                  Update PSA DiagBox WITHOUT Internet! V7.24 Allready PATCHED
                  Envoyé par scarymistake
                  update diagbox v7 allready patched
                  i also put in the install iso
                  (from de master debutant)
                  first un-install old diagbox
                  installation :
                  Installing the iso
                  after activation, shut duwn diagbox and start it up and you will have version 07.02
                  ready to update but use only the of-line updates (otherwise he will be deactivated) and then you must start over again
                  use only 32bit windows
                  torrent link
                  psa diagbox without internet! V7.04 allready patched scary torrent
                  tanks to buck rogers
                  video how to install v7 already patched and update windows 7 32bit
                  [video=youtube]http://www.youtube.com/watch?v=9bdndnbifae[/video]
                  new update v7.24
                  • majidou5
                    oui c est vrai version 7.22 seulement
                    • MarcusP
                      • septembre 2013
                      Y at-il une liste de ce qui a changé dans les nouvelles mises à jour?
                      Merci pour le travail dur.
                      (Traduit par Google Translate)
                      Is there a list of what has changed in the new updates?
                      Thanks for the hard work.
                      • Orkiller74
                        • septembre 2013
                        +1, Si on pouvais avoir le détail de chaque mise à jour (voir si c'est utile...)
                        Merci en tout cas pour la mise à disposition !
                        • Boyan
                          • septembre 2013
                          • 46
                          TLCD fix program. Quelqu'un peut-il expliquer ce que c'est?
                          Merci.
                          B
                          • denver
                            • septembre 2013
                            Merci scary !! J'ai un windows 8, j'vous donne les info si tout passe bien
                            • IYAD12
                              • 159
                              bonsoir j ai la version 7.20 comment faut pour avoir la version 7.24 merci les amis
