Problème installation Diagbox V7
  • harry974
    • juillet 2015
    • 140
    yes
    it is simple for explains!
    • manu06
      • 96
      Envoyé par Simple
      I don't understand what you have been trying to do, because you have not explained it.
      But the upgrade process goes like this (S=Scarymistake M=Maitresox X=Simple):
      DiagBox S7.01/02 --> S7.xx-7.57 --> M7.57-7.58 --> M7.58-7.62 --> M7.62-7.66 --> M7.66-7.74 --> M7.74-7.76 --> X7.76-7.77
      What you have done is: DiagBox S7.01/02 --> S7.xx-7.57 --> S7.67-7.60 --> S7.60-7.61 (Scary has changed the updates after that)
      If you don't do that you get problems and you may need to install from the beginning.
      je voudrait les liens pour tout ré installer
      • manu06
        • 96
        Super Membre
        Inscritjuillet 2013PaysFranceVilleCannesMessages69Merci42Remercié : 2 fois en 2 mess.Pouvoir de réputation4
        meme problème après telecodage en ligne message: "les applications sont maintenant désactiver"
        mais sa ne me demande pas de le réactiver!
        dois je tout ré installer?
        diaagbox 7.76 Windows 8
        • manu06
          • 96
          Tous ré installer jusqu'à 7.76 tout nikel sur un Windows 8 64bits
          • Simple
            • août 2015
            • 253
            Envoyé par manu06
            @manu06,
            The official recommendation is to install on Windows 32 bit (XP - 7), you may be able to install DiagBox on Windows 64 bit, but can you make it work?? You will meet problems you may not be able to solve...
            I have successfully installed DiagBox on Windows 10 (last year when it was beta) and this year after official release and wrote a small post on how to do it. But PSA does NOT recommended it or support it.
            So, if you install on Windows 64 bit, good luck, I hope you will be able to make it work..
            • manu06
              • 96
              Par contre installer sur un autre modèle xp et message " connecté une vci"
