Besoin divers informations suite à installation de diagbox
  • Simple
    • août 2015
    • 253
    I think you missunderstood me.... I actually manged to crack it... It will work for you.
    Just click on the link, download the files and install as described in the procedure.
    In fact, since then, I found an easier way.. I will post it shortly..
    • Simple
      • août 2015
      • 253
      Upgrade to DiagBox v7.77 (if you have upgraded to 7.76).
      Please notice that this is intended for educational purposes and that you perform any or all the below procedures at your own risk. I hold no responsibility for any issue you may face.
      Procedure:
      1- Go to C:\AWRoot\bin\fi\ and create another copy of cashe folder naming it cashe.org.
      2- Download the attached file, Expand it and copy the contents of the updt_77 to C:\AWRoot\dtwr\updt\ directly replacing and overwriting existing files and folders.
      3- Run DiagBox, it will start the upgrade process, when it finishes successfully click ok, it will run for the first time and will give 6 or 7 error message, keep clicking ok until DiagBox closes down.
      4- Copy the 13 files that start with “fr.actia.AWF.xxxxxxx.dll” from cashe.org into the (empty) cashe folder.
      5- Run DiagBox and it will run successfully.
      If you don’t like 7.77 update or you have an issue with it. Run Maitresox’s 7.74 to 7.76 again and it should successfully downgrade it to DiagBox v7.76.
      Simple.
      • ballajunior
        • juillet 2015
        • 31
        Envoyé par Simple
        One more thing Simple, I went on another site to read about the Maitresox's 7.74 to 7.76 upgrade... Seems that there is an issue with the language... French becoming EN, I think.
        Do you know if your upgrade will fix it or not?
        Thanks in advance for your feedback.
        • Simple
          • août 2015
          • 253
          I have not tried it, you can try it if you wish, but I dont think it will change the language..
          In any case, you have the ZIP file, you can unzip it and see if you can do something with the language (there are some configuration files).. unfortunately I dont speak French, but if you do, there will be a lot of very very happy people...
          By the way, It is sorted, I posted a new message on the main board, this is the link:
          Dernière modification par Simple, 02 novembre 2015, 14h47.
          • ballajunior
            • juillet 2015
            • 31
            Envoyé par Simple
            http://www.lesamisdudiag.com/diagbox...tml#post181918
            Hi Simple,
            translation mostly done... Just waiting your feedback via Tlemcen... If you have the procedure for the "switch" to French, I could translate it at the same time.
            Cheers.
            • Simple
              • août 2015
              • 253
              I will write the procedure and post it on the Diagbox 7.77 (8.13) Update (en français) thread.. Feel free to translate it once done..
              Thanks.. Simple.
