Upgrade to DiagBox v7.77 (if you have upgraded to 7.76)
Please notice that this is intended for educational purposes and that you perform any or all the below procedures at your own risk. I hold no responsibility for any issue you may face.
Procedure (Offline Update):
1- Go to C:\AWRoot\bin\fi\ and create another copy of cache folder naming it cache.org.
2- Download the attached "updt_77u.zip" file, Expand it and copy the contents of the updt_77 forder to C:\AWRoot\dtwr\updt\ directly, replacing and overwriting existing files and folders.
3- Run DiagBox, it will start the upgrade process, when it finishes successfully click ok, it will run for the first time and will give 6 or 7 error message, keep clicking ok until DiagBox closes down.
4- Copy the 13 files that start with “fr.actia.AWF.xxxxxxx.dll” from cache.org into the (empty) "C:\AWRoot\bin\fi\cache\" folder.
5- Run DiagBox and it will run successfully.
If you don’t like 7.77 update or you have an issue with it. Run Maitresox’s 7.74 to 7.76 again and it should successfully downgrade it to DiagBox v7.76.
DiagBox can be used in any of the 20 available languages (tested on v7.76 and v7.77) and this is how to do it:
1- For DiagBox:
- Open the File Explorer and navigate to "C:\AWRoot\dtrd\trans\", find the file "Language.ini" and create a copy "Language.ini.org".
- Open the file Language.ini and under [LANGUAGE], change "Current=en_GB" to "Current=fr_FR" and save (I commented the original and added the new line to activate the French language).
[LANGUAGE]
;Current=en_GB
Current=fr_FR
2- For Lexia:
- Navigate to "C:\APP\LEXIA\EXE\" find the file "langue.ini" and create a copy "langue.ini.org".
- Open the file "langue.ini" and under [DicoMap], change all "%LG%" to FR (I commented the original 4 lines and added changed 4 lines to change Lexia's language to French).
[DicoMap]
;CITACT=..\Dico\CITACT%LG%.dbz,APV
;CITTT=..\Dico\CITTT%LG%.dbz,APV
;CITTV=..\Dico\CITTV%LG%.dbz,APV
;THESAU=..\Dico\THESAU%LG%.dbz,APV
CITACT=..\Dico\CITACTFR.dbz,APV
CITTT=..\Dico\CITTTFR.dbz,APV
CITTV=..\Dico\CITTVFR.dbz,APV
THESAU=..\Dico\THESAUFR.dbz,APV
- Navigate to "C:\APPLIC\LCTLEX3\", find the file "Dico.txt" and create a copy named "Dico.txt.org".
- Open the file "Dico.txt" and change the line "Dico=THELEXGB.DBZ" to "Dico=THELEXFR.DBZ" changing from English to French.
;Dico=THELEXGB.DBZ
Dico=THELEXFR.DBZ
3- For PP2000:
- If you wish to change PP2000, Navigate to "C:\APP\OutilRep\exe\", find the file "Dico.txt" and create a copy named "Dico.txt.org".
- Open the file "Dico.txt" and change the line "Dico=THESAUFR.DBZ" to "Dico=THESAUGB.DBZ" to change to English,
;Dico=THESAUFR.DBZ
Dico=THESAUGB.DBZ
The language change is achieved by replacing the "**" in "Dico=THESAU**.DBZ" with 2 letters representing the language you want, you can choose any of the 20 available languages.
You can also use a script to change "en_GB" to "fr_FR" but be careful, because some listing are definitions for languages like Arabic or German etc.. But if you dont care and other languages are not needed, I think it will work.
Language table added
You can also use the attached Country Codes table to change the codes in your system, example for English:
Codes for DiagBox (DBX) go into C:\AWroot\.... in (2 Chrs.) statements such as "LauncherEN.DBZ" or (5 Chrs.) statements such as "Current=en_GB"
Codes for Lexia / PP200 go into C:\APP\... in statements such as "Dico=thesauGB.dbz" (in file Dico.txt)...
Please notice that you can have DiagBoX, Lexia and PP2000 eaxh working in a different language...
PP2000 Language fall back and font sizing
Also, for PP2000, the statement in C:\APP\OUTILREP\EXE\LANGUE.INI:
[BackUpDico]
BackUpThesau=\app\outilrep\Dico\thesauGB.dbz
will determine the language used in case you choose an unsupported language (or missing language files). In this case you may also add the statement Arial=10 (or any font size that you may prefer) like below.
[FontScale]
Arial=10
p.s. Simple trick, if you wish to play with the font size, change the statement in Dico.TXT "Dico=thesauGB.dbz" to "Dico=thesau.dbz", this will force the system to use the backup language of your choice with the Arial fonts you decided... I tried it for PP2000, and it works.
Lexia resizing and screen positioning
And since I am at it, you can also position and resize Lexia on the screen to your liking by navigation to:
C:\APP\LEXIA\EXE\ and finding the file: "ecran.ini".. open it using notepad and under:
[GENERAL]
position_X =0
position_Y =0
largeur_ecran = 1024
hauteur_ecran = 748
I think it is self explanatory, the X and Y affect positioning on the screen (from top left), and the ones I cant read are the Width and Height in pixels...; Try "position_X =200", "position_Y=100", "largeur_ecran = 800", "hauteur_ecran = 600" and restart Lexia.
Once again, This is for experimental and educational use and I hold no responsibility for any damage to your system..
Enjoy the French version of DiagBox 7.xx
![Cliquez sur l'image pour la voir en taille réelle
Nom : DB1.jpg
Affichages : 1
Taille : 39,4 Ko
Nom : DB-777.jpg
Affichages : 1
Taille : 85,3 Ko
I have just heard from maitresox that he added a patch to switch to French in his release..
Simple.
1- For DiagBox:
[LANGUAGE]
;Current=en_GB
Current=fr_FR
2- For Lexia:
[DicoMap]
;Dico=THELEXGB.DBZ
Dico=THELEXFR.DBZ
3- For PP2000:
;Dico=THESAUFR.DBZ
Dico=THESAUGB.DBZ
[BackUpDico]
[FontScale]
Arial=10
[GENERAL]
position_X =0
position_Y =0
hauteur_ecran = 748
Simple.
