DiagBox 8.01 Installation
  • aguy22
    • octobre 2016
    • 192
    #181
    Hi,
    My answer is a little bit late... No internet this week
    @simple
    I'm sorry my question hurt yourself. Like said xlv600 I was posted this post just to inform yourself about this missing. I got before 4.3.5 firmware in this forum (with your contribution) but just you said is became with the 8.45 update, I'm feel free to get it from upodates to verify...
    I didn't remember that you already said why this firmware are not present in update, I'm new is diagnoitic environnment and it's difficult for me to put right informations in right case.
    Sorry and thank you for your support
    I knew "aid mabrouk" but not "eid mubarak" spelling ;o). You to (with late) My father was muslim from Algeria.
    @xlv600
    Thank you for your support and explanantions, i didn't made better ;o)
    And congratulation for your job !! good luck
    Nice day & thank you to all (@patber)
    • Simple
      • août 2015
      • 253
      #182
      Thanks aguy22. Rest assured that what you wrote did not hurt me and I am not upset either. I just felt that the post became too long for a new commer to read. In fact, I am now contributing to this lengthy thread, but I am answering so that I am not rude to you.
      We all started life humble and ignorant (knowing little), and when we increase in knowledge, we need to increase in humbleness as well.
      Have a joyous time.. Salam, Simple.
      • Warlord
        • 183
        #183
        Bonsoir à tous
        Je viens tout juste de reçevoir la VCI lexia et j'éssaie d'installer diagbox.Javascript Erreur d'initialisation Impossible de charger les fichiers de sécurité,fermeture.
        La solution est certainement dans un des posts mais l'anglais voilà quoi,merci pour votre aide.
        Opel Corsa Année 2019 120ans
        • Simple
          • août 2015
          • 253
          #184
          Try this:
          • Warlord
            • 183
            #185
            Merci Simple,j'ai pu faire l'install de la version 7.01 et faire la mise à jour à la 7.57 je crois mais c'est juste recule pour mieux sauter mais le résultat et le meme une fois que je veux passer à la 8.01 les problème rencontrer avant sont les memes maintenant en voulant faire l'install de cette version franchement je comprend pas....Que ça soit aussi simple pour la 7 et la 8 il y a je ne sais combien de problèmes qu'on rencontre pendant l'installation.
            Quand je lance l'activateur ça me demande de remplacer le fichier cfg.bin (oui/non/tous) ?
            Ben là quelque soit le choix ça défile sans passer à autres choses....
            • patber
              • 4210
              #186
              Salut tu disais être un geek? Regardes ici.
              • Warlord
                • 183
                #187
                Envoyé par patber
                https://www.google.ca/search?source=...initialisation
                Effectivement je le suis mais si tu as lu mes précédents méssages tu t'attarderais pas sur le mot Geek bref en voulant installer la 8.01 en premier Simple m'a indique qu'il fallait installer la version 7 donc je l'ai fait et une fois que j arrive pour éffectuer celle de la 8 j'ai ce méssage d'erreur.Je dit bien que la version 7 ne l'affiche pas ce méssage mais la 8 oui par conséquence à quoi m'a servi de passer par l'installation de la version 7 ? Rien parce que tout simplement je bloque sur le meme problème.T'inquiète j'ai éffectué des recherches largement j insiste bien sur dessus avant que tu postes ton lien google... Mais bon.
                • patber
                  • 4210
                  #188
                  Salut quel système d'exploitation? Quelle version de Java?
                  • Warlord
                    • 183
                    #189
                    Envoyé par patber
Nom : 		JAVA.PNG
Taille :		66,1 Ko
ID : 			313517Cliquez sur l'image pour la voir en taille réelle
Nom : 		SY.PNG
Taille :		12,0 Ko
                    Si tout le monde avait les compétences personnes ne poseraient de questions....
                    • Simple
                      • août 2015
                      • 253
                      #190
                      Uninstall Java 8, you don't need it. DiagBox 8.xx comes with its own Java 7.
                      • patber
                        • 4210
                        #191
                        Thank you Simple i just told him to do so.Keep on the good work!
                        • Warlord
                          • 183
                          #192
                          Bonsoir à tous,
                          Je viens apporter de bonne nouvelles concernant mon installation de diagbox.Installation réussite je suis à la version8.17,demain je vais me consacré à l'installation des drivers de la VCI.Par contre après avoir supprimer les icones sur le bureau ils ne sont jamais réapparu c'est normal ?
                          Bonne soirée.
                          • patber
                            • 4210
                            #193
                            Salut parfait expliques aux membre ce que tu as fait cela risque d'en aider plus d'un.
                            • Warlord
                              • 183
                              #194
                              Envoyé par patber
                              Donc après avoir eu un échange par tchat,j'ai supprimé l'install v7 (avec l'outil) ainsi que Java 8 qui à ce que j'ai compris m'envoyait ce méssage d'erreur "javascrip....Un coup de ccleaner pour nettoye tout ça et une suppression manuelle de certains dossiers qui serait rester après la désinstallation,j'ai pas du tout faire mais bon.
                              -Installation de java7 récupéré sur le net
                              -Installation de diagbox 7.01 https://www.lesamisdudiag.com/diagbo...iagbox-v7.html (avec les mises comme explique dans le tuto la 7.44 et ensuite la 7.57 (bien sur redémarrage pc à chaque install des mises à jour).
                              -Début de l'installation de la 8.01 https://www.youtube.com/watch?v=100rbi5Ge20 (tuto en vidéo au début du topic posté par Simple).
                              -Renomer l'ancienne install (dossier AWRoot7).
                              -Suivre la procédure de la vidéo en sauvegardant comme expliquer sur la vidéo.....
                              • aguy22
                                • octobre 2016
                                • 192
                                #195
                                @Warlord
                                Salut, impeccabler pour ton installation. Simple te disait que diagbox vient avec sa propre API java? donc pas besoin de pré-installer java. Diagbox installe les composants dont il a besoin ;o)
                                Tiens nous au courant pour la suite : 8.17-8.47, si tu as des problèmes ou non peux-tu préciser ton environnement : système windows, VC++, .net framework... ?
