DiagBox 8.01 Installation
  • Simple
    • août 2015
    • 253
    #76
    Good, but no one knows what was the problem!! can you write it so that other (new) users may learn, please.
    Yes, and you don't have to re-edit your version.ini, but I advise you to edit it so that everything works and it indicates what you have installed, for example:
    8.17 --> version=07.817
    8.38 --> version=07.835
    • aguy22
      • octobre 2016
      • 192
      #77
      Hi Simple,
      Thank you for your answer !
      I knew the variable maj_com in ap.ini, I asked just wich version updated the firmware and you answer me : 802 ;o)
      I've always the same error with XP installation :
Nom : 		diagbox8-vcc-sp1-error.jpg
Affichages :	2
Taille :		15,3 Ko
      I've tested installation with VC++ 2008 x876 in the initial version and in SP1 from microsoft website and with the version in c:\telemaintennace ( path c:\telemaintenance appears only with installation of 8.01 in WIndows 7 noit in xp version )
      I've made too many test and I have a lot of VM to think the problem coem from materials or virtualbox installation...
      I've installed successfully diagbox 8 in windows 7 with his updates without any errors with .net frameworks v3.51 & 4.6.1 !!
      2 little questions:
      - I saw the file in list a softwares : "Cache Contents Restorer" but no present in instriuction ?
      - what gives to stay under version 8.08 in "ISO 639-1" norm ? a compatibility with olders vehicules ?
      Thank you ;o)
      • aguy22
        • octobre 2016
        • 192
        #78
        Hello,
        I've found an update 8.35-8.38 have you an active link for updates between 7.83(old ref) - 8.35 ?
        thank you
        • Simple
          • août 2015
          • 253
          #79
          @aguy22,
          The Windows XP I use is: Windows XP Professional Version 2002 Service Pack 3. I have NO problem with this release.
          But, I remember having problems with one Windows XP CD, I don't remember which one (may be XP, or XP SP1), and I don't remember the type of error, it was 3 years ago.
          I don't know why VC++ 2008 9.0.30729.17 did not solve your problem but VC++ 2008 SP1 did, probably related to your setup. I used vcredist_x86_9.0.21022.8, 9.0.30729.17, 9.0.30729.4148 and 9.0.30729.6161 and they all worked.
          Cache_Restorer:
          Sometime when editing DiagBox to make new updates work, DiagBox removes all contents of the cache folder and you cannot operate it, hence the restorer.
          DiagBox 7.72/8.02:
          It was released in 2015 (I think), it is compatible with all vehicles, it just hasn't the latest vehicles or program fixes.
          Update 8.38, is only for Lexia and PP2000, NOT all DiagBox.
          If you have DiagBox 7.82/3 and would like to update the Lexia and PP2000 to 8.38, then:
          1- look for the thread (Lexia & PP2000 (from DiagBox 8.35)) and follow instructions to replace your current C:\APP with the new one.
          2- Use the update from 8.35-8.38. (I canno't find it on this site, may be I forgot to post it here!!)
          Dernière modification par Simple, 13 février 2017, 19h03.
          • spoky
            • 226
            #80
            j'ai trouvé ce lien , mais est ce que c'est la bonne solution pour l'udate de 8.17 a 8.xx ?
            http://diagbox776.over-blog.com/2016/11/lexia-diagbox-v8.01-8.35-telecharger-et-installer-sur-win-xp-10.html
            attendons l'avis de Simple.
            308 1.6Lhdi 92ch , Seat Ateca 1.6Tdi 2017 H7
            • spoky
              • 226
              #81
              Envoyé par Simple
              @agut22,
              APP_Update_817-837.exe 75.2 MB
              https://mega.nz/#!Z0EHmRwB!T4QsYzZxrNiatSoRlacjCw7oghPpb0H200MO03B M2jg ??
              edit:
              does not work !
              If you are in version 8.17 ... kill ... to close all .... and install this update, reboot diagbox
              .... take into account the internet update .... then start diagbox ...
              Version displayed ... 8.17! ?
              diagbox en 8.17 mais...
              .ini pp2000 --> NOM=OUTILREP
              VSOFT=600.79
              .ini lexia -----> VSOFT=500.74
              VSOFTVISU=Lexia (500.74)
              • aguy22
                • octobre 2016
                • 192
                #82
                Ok thank you for all your replies ;o)
                For my problem of installation on windows xp, I have a windows XP manually updated to SP3, not the last released including the SP3... May be this is the problem ??
                I'm going to search to download a final windows XP3 to test it !
                For update file I need the link between 8.17 and 8.35, I found the 8.35-8.38 ;o)
                Ok merci pour le lien ;o)
                Je vais tester cela après avoir trouvé une version finale de windows XP avec le pack SP3 inclu dedans...
                Bonne fin de journée
                • sophiane
                  • 222
                  #83
                  Bonsoir mon disque dur a lâcher donc j ai changer etc..
                  mes quand je mes diagbox 8.01 il me mes nsis error quand j ouvre pour installer merci
                  panasonic cf19 mk6 - avec tout mes diag
                  • Simple
                    • août 2015
                    • 253
                    #84
                    DiagBox profile is created using your PC ID. This PC ID is a result of compiled information about some components, one of which is the hard disk.
                    If you change the hard disk, you need to re-install, unless you are using Virtual Machine.
                    • sophiane
                      • 222
                      #85
                      Bonsoir probleme résolue parcontre quand je mes l update 8.02
                      la mise a jour par internet ne s'est pas terminée correctement
                      • Simple
                        • août 2015
                        • 253
                        #86
                        Read through this thread and try the suggestions given in the posts..
                        • kilm13
                          • 15
                          #87
                          Merci beaucoup à Simple pour son travail et pour le partager avec nous !
                          Envoyé par spoky
                          Problème !...
                          la mise a jour DiagBox_updt_802_Simple , redemarrage de diagbox...erreur !
                          La même chose m'est arrivé au moment de relancer diagbox après la mise à jour V08.02 et après les mises à jours suivantes aussi. Il m'a suffit de redémarrer windows et quand on relance diagbox ça passe normal.
                          • lululoul
                            • 52
                            #88
                            coucou les amis quelqu'un aurait il une raj depuis 7.47 à 7.57 afin que je puisse installer ceci ?
                            d'avance merci
                            • Simple
                              • août 2015
                              • 253
                              #89
                              As far as I remember the file "config.sys", which is needed for DiagBox 8 installation, is created by update 7.45.
                              Check in "C:\AWRoot\dtwr\cfg\", if you find the file "config.sys", then you do NOT need to upgrade to 7.57 and you can start DiagBox 8.01 installation, if not, then you need to upgrade.
                              • rochabob
                                • juin 2017
                                • 8
                                #90
                                Hello how are you?
                                First of all thank you for taking the time to help us.
                                I had a bit of work, but I was able to upgrade to 8.17.
                                Now is it possible to make updates on the engine and change from C4?
                                I am registered at citroenservice.
