Lexia & PP2000 update 8.47-8.50 (DiagBox v8.50)
  • Simple
    • août 2015
    • 253
    The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
    APP_Update_847-850.exe update should only be attempted if you have a working DiagBox v07.847.
    Link is provided in the attachment for "APP_Update_847-850.exe". This is intended to update Lexia and PP2000 components of DiagBox 8.47 to 8.50. The versions of Lexia and PP2000 will remain 500.74 and 600.80 respectively.
    Procedure:
    1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
    2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all associated processes to enable overwriting without conflicts.
    3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
    Done..! you may run DiagBox as usual.. Notice that DiagBox version will change to 07.850 after the update..
    Have fun!
    Lexia language is set to English and PP2000 to french, if you wish to change them, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa.
    P.S. DiagBox has been running on Firmware 4.3.5 since 8.45.
    Regards, Simple.
  • belcitroen
    • 80
    How to change the language english to espagnole in lexia
    • Simple
      • août 2015
      • 253
      Envoyé par belcitroen
      Very good question, but the answer is already on the forum.
      A search for language change or my posts on this forum may very much help..
