How to get Vediamo to work with VAS5054A
  • alice88auto
    • 34
    Tips and guide: Vediamo working with vas5045a head – how to set up
    try vediamo 4.02.02. it has setting for passthru.
    try vas5054a x64bit driver. there are two threads regarding vas5054a in forum from two members.
    edit slave.ini in c:\program files (x86)\vediamo\caesar\. Change devicename to:
    ; ——————-; PartJ configuration; ——————-
    DeviceName=”Softing – VAS5054A#082145725″
    change “serial number” with your vas5054A serial number
    try ‘CAN’ ecu. VAS driver is not fixed yet for k-line ecu.
    good luck and enjoy the experimental and educational journey.
    Good to know: vas 5054a also can work with xentry
    211/203/204:
    I Have USED Clone VAS5054 w/OKI on 211/203/204 Body styles can be viewed, things can be activated, error codes was able to clear, adaptation was able to be completed, VIN was read, cars was identified
    C203 2003:
    I am testing Xentry Passthru 12.2017 with VAS5054 on C203 2003. everything works without problem. on line k too.
    2006 CLS55 AMG, 2007 R Class, 2008 Sprinter:
    I used my VAS5054a with the 2006 Mercedes CLS55 AMG, 2007 R Class, 2008 Sprinter, all in DAS. Everything worked except the ignition detection.
    C 250 2014
    I used VAS5054a with C 250 2014 using Xentry, everything works fine, no sense of ignition, but Xentry gives you a check box to manually select.
    2006 for Mercedes:
    I have not tried more than 2006 for Mercedes, but I’m sure the limit is in software / drivers.
  • patber
    • 4210
    Good day,Vediamo in a Toyota - Lexus - Honda section? I think that you are full of shit and that you should stay in China.Thank you.
