aide suppression fap 207 1.4 hdi 2010
  • stefan
    • 61
    bonjour à tous je voudrais savoir si le galletto 1260 ou kwp2000 est compatible avec le calculateur de ma 207 1.4 hdi modele 2010.
    merci ce serait pour supprimer le FAP.
  • dep-info
    • 209
    Galletto 1260 :
    PEUGEOT BOSCH EDC15C2 READ AND WRITE PEUGEOT SIEMENS SID 881/801 E3/4 READ AND WRITE
    PEUGEOT SIEMENS SID 804 E4 READ AND WRITE
    PEUGEOT BOSCH EDC16C3.9 READ AND WRITE
    PEUGEOT BOSCH EDC16+C34 READ AND WRITE
    PEUGEOT SIEMENS SID 803 E3 WRITE
    PEUGEOT SIEMENS SID 803A E4 WRITE
    PEUGEOT BOSCH ME744 READ AND WRITE
    PEUGEOT BOSCH ME745 READ AND WRITE
    PEUGEOT MARELLI IAW 48P WRITE
    PEUGEOT MARELLI IAW 48P2 READ AND WRITE
    PEUGEOT IAW 6LPA READ AND WRITE
    PEUGEOT IAW 6LPA01 READ AND WRITE
    PEUGEOT SAGEM 2000 2A READ AND WRITE
    PEUGEOT SAGEM 2000 PM2 READ AND WRITE
    PEUGEOT SID 881/801/804/806 Boot READ AND WRITE
    Pour le KWP2000 laisse tomber il fait pas les recents. par contre tu peux peut etre trouver ton bonheur sur du Galletto 2 ou MPPS
    MPPS :
    Peugeot,106,1.1L,Bosch,MP7.4.4,Kline,Yes,Yes,No
    Peugeot,206,1.4 HDI,Bosch,EDC16C3,Kline,Yes,Yes,Yes
    Peugeot,206,1.6 HDI,Bosch,EDC16C3,Kline,Yes,Yes,Yes
    Peugeot,206,1.6 HDI FAP,Bosch,EDC16C34,Kline,Yes,Yes,Yes
    Peugeot,206,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,207,1.6 HDI FAP,Bosch,EDC16C34,Kline,Yes,Yes,Yes
    Peugeot,307,1.6 HDI,Bosch,EDC16C3,Kline,Yes,Yes,Yes
    Peugeot,307,1.6 HDI FAP,Bosch,EDC16C34,Kline,Yes,Yes,Yes
    Peugeot,307,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,406,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,406,2.2 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,607,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,607,2.2 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,806,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,807,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,807,2.2 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,Expert,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,Partner,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Peugeot,Ranch,2.0 HDI,Bosch,EDC15C2,Kline,Yes,Yes,No
    Galleto 2 Ok : http://www.chinasinoy.com/upload/pro...r_list_car.pdf
    • evobag
      • 33
      Ok galletto 2 san souci
      FGTech Galletto 2-Master V51 BS - $68.00 : go car diagnostic , scanner , car , auto scanner, car diagnose, diagnostic tools
      deja commander sur se site
      • diagnounou69
        • 225
        bonsoir :mon frère il faut bien expliquer de quel calculateur tu parle bosch EDC...pour avoir une bonne repense ça ne se fait pas de donner juste la marque de tas voiture si c'est un EDC16C34 il te faux un BDM100 est voila .
        • stefan
          • 61
          ok desoler j'ai regarder c'est un EDC16C34 un grand merci pour votre aide.
          • evobag
            • 33
            Comme tu es novice le bdm et une très mauvaise idée car il va faloir que tu ouvre ton calculateur et que tu soude des fils a l intérieur si tu te trompe le calculo et hs
            donc le mieu pour toi c de prendre un galletto v2 car le v1 ne fait pas le CAN bus et le kwp2000 non plus
            et si tu veu un Prog de qualité contacte Tom
            • Tomtom71
              • 1127
              Envoyé par evobag
              +1 tout à fait d'accord ! En + tu dois le connaitre celui qui me fait les cartos au top :-)
              • stefan
                • 61
                ok merci je vais prendre le galletto v2 .
                merci quel logiciel puis-je utiliser avec ..
                si vous en avez un a me recommander merci.
                • evobag
                  • 33
                  Logiciel pour faire koi pour enlever le fap ou pour rajouter de la puissance et du couple ?
                  • Tomtom71
                    • 1127
                    Je pense qu'il parlait du logiciel pour le galletto ! Si c'est le cas il te sera fournit avec ...
                    • dep-info
                      • 209
                      Envoyé par diagnounou69
                      --' Via ODB c'est possible, pas obliger de passer par un BDM et son banc !!
                      • stefan
                        • 61
                        merci c'était pour faire fonctionner le galletto v2.
                        Pour supprimer le FAP et plus tard rajouter un peut de puissance et du couple si possible bien sur .
                        • evobag
                          • 33
                          Ok le software et livrer avec le galletto2
                          pour le fap off aucun logiciel ne fonctionne pour les edc16c34 il faut le faire manuellement dans le fichier origine de ta voiture il faudra que tu le fasse faire par quelqu'un du forum tomtom71 déjà passer par lui et aucun souci
                          • stefan
                            • 61
                            ok je te remercie et si je veut donner un peut plus de puissance a ma voiture quel logiciel me conseillerais tu .
                            • Tomtom71
                              • 1127
                              Envoyé par stefan
                              Win ols a mon avis !
                              Mais si tu poses ces questions a mon avis ne te lance pas la dedans ;-)
